Conditional node can't compare anything, except "equal"
Soffort
Post by Soffort »
Hello, Steinar.
I was try to check incoming file length in Conditional node, and it doesn't work.
After all tests, I found, that Conditional output is always Success if I use >, <, >=, <=. Only = works.
1>2 - Success
1<2 - Success
2<1 - Success
2>1 - Success
And go on :)
But 1=2 - Failed. And 1=1 - Success.
Re: Conditional node can't compare anything, except "equal"
Are you sure you're running the latest patch from 12. sept?
Soffort
Post by Soffort »
Yep. I download latest version right now.
Oh damn it! Seem to be a mixup of some files on my HD :oops: :roll:
Can you please try this package: ffastrans.com/download/FFAStrans_Patch_1710.7z
There's also the ip fix for the rest api.
Soffort
Post by Soffort »
Both works fine, thank you!
