AVID Conflicts and MSVCR120.dll missing
filip mit f
Post by filip mit f »
Hi guys,
I am encountering many problems with AVID Media Composer since I've installed FFAStrans on my computer. I've already done a new installation of Windows, Avid and everything on my computer. It has been working propertly for a short period of time, but than started exibiting the same problems.
The most apparent problem is the QuickTime notification that MSVCR120.dll is missing. I have been getting these notifications since I've installed FFAStrans and since than my AVID has been crashing permanently.
I would very much appreciate any help I can get.
I have allready installed Visual C++ Redistributable x64 and x86 and tried reinstalling everythig but nothing has helped. :(
Thank you guys
Here you can see the warnings:
https://ibb.co/fcQ7o6
https://ibb.co/gXeso6
Re: AVID Conflicts and MSVCR120.dll missing
Hi filip mit f, thank you for using FFAStrans and welcome to the forum! :-)
I'm sorry you have such problems with Avid and FFAStrans but FFAStrans does not do anything you your system. With the last version, nothing needs to be installed or uninstalled, except if you want to use th QT-ref conversion feature in FFAStrans. In that case you need to install QuickTime. Other than that, FFAStrans should not conflig with, or alter your system in any way. I run Avid along side with FFAStrans without any issues.
