Do not encode files with the same name after the update
raccvet
Post by raccvet »
Try to describe in broken English.
Problem: there are several files that are updated daily but still have the same name. On new versions of the program, the files after one conversion are no longer converted, but in version 7.2 if the file has the same name, but changed the date and size, it will still be converted. Tell me how to set up a similar function in new versions.
Re: Do not encode files with the same name after the update
Hi raccvet, thank you for using FFAStrans and welcome to the forum! :-)
The method was changed due to some reliability issues. So the current version only register the complete path as unique file and you can't change that behavour. I will however look new ways to deal with this issue, so stay tuned.
