I have a question. Is there a way in FFAStrans to determine whether a file is mxf op-atom?
Thanks.
Taner
Determine OP-Atom-files
Re: Determine OP-Atom-files
Hi Taner,
There is no inbuilt functionality for this but you can still get that info with a little trickery. Please import and look at the attached workflow.
PS: I will look at adding more mxf info variables in future versions.
- Check OP type.zip
- (1.27 KiB) Downloaded 688 times
Many many thanks for your efforts! It works great! The only thing I had to do was to download and copy mxf2raw.exe-file into the mxf_tools-folder as it was not present there.
Taner
Taner
