fade in fade out with overlap
dsmarques
Post by dsmarques »
I need to create a new video with an intro video and an out video. The big issue is I need a transition effect between the main video and the out video (fadeout-fadein with an overlap during the transition process (20 frames)). I placed a fade filter in the workflow but the fade in of the insert media only starts after the fade out of main video finishes. Any tip to solve this issue?
Regards
David
Re: fade in fade out with overlap
Ah, I should have thought of that before. It should be easy to implement so will will try and do that for the next version. You can of course create a custom script but that means you need to be familiar with AviSynth.
dsmarques
Post by dsmarques »
Thanks Steinar.
I tried with this script, but I'm getting the error "Dissolve: one clip has audio and the other doesn't (not allowed)"
Here is the code:
# Variables:
# m_clip = The last returned AviSynth media
# _ffas_video = <original video>
# _ffas_audio = <original audio>
# _ffas_height = <source height>
# _ffas_width = <source width>
# _ffas_work_fdr = Working folder for the workflow
av = FFAudioSource("e:\media-fabio\inout\intro6.avi")
nv = FFVideoSource("e:\media-fabio\inout\intro6.avi")
AudioDub(nv, av)
Dissolve(m_clip, nv, 20)
Return m_clip
For sure I'm doing something wrong. Any help will be appreciated.
Regards,
David
dsmarques
Post by dsmarques »
Solved. With this code works like a charm.
inv = AVISource("e:\media-fabio\inout\in.avi").ConvertToYV12()
novo = Dissolve(inv, m_clip, 1)
nv = AVISource("e:\media-fabio\inout\out4.avi").ConvertToYV12()
m_clip = Dissolve(novo, nv, 25)
Return m_clip
Thanks for your help.
Regards
David
