Folder Monitor issue
Vombat1979
Post by Vombat1979 »
Hello guys.
Can Folder Monitor check not just file name but some other condition?
Let explain my workflow:
I have some input folder with deep subfolders and thousands files, but time to time appears file with same name/path like was before (for example new version of file). It seems to me monitor ignore file if file with same name was before, even if size and modify time is changed.
So, have you solution except submit files and clear history features?
This solution have to work with next job:
In input folder I put two files TestA and TestB.
FFAStrans process files TestA and TestB.
I replace file TestA. (different modify time).
FFAStrans process files TestA.
Sorry for my English. It is not my native language.
Thank you in advance,
Vombat
Re: Folder Monitor issue
Hi Vombat, sorry for the late reply but thank you for using FFAStans and welcome to the forum! :-)
Unfortunately there is no easy way of dealing with this but I plan to address the issue in the next version of FFAStrans.
