Having a bit of conceptual trouble of how best to setup a few workflows. Using latest 8.2 version of FFAStrans
Ideally I'm trying to identify clips that have a specific Rotation flag set -180 and 180 for phones that shot landscape video. I'm trying to use a command node to write a file and use the Read & Between functions to find the specific text.
What is best way to direct the files to be processed once the condition is met? Just move file to a another watch folder? Or will is there a better way I should approach the task?
a
Detect Rotation and move
Re: Detect Rotation and move
Hi a1000, thank you for using FFAStrans and welcome to the forum!
It's easier if you share your workflow and what you have done so far. But generaly, once a condition is met you basically just add new steps and make sure they execute on "Success", which is the default.
Thanks, got the problem solved. I will post solution to this thread.
I've added rotation detection to the upcoming 0.9.0 version so stay tuned
