Cannot load a 64 bit DLL in 32 bit AviSynth
silicontrip
Post by silicontrip »
I'm not sure why FFAS is trying to use a 64 bit dll in the 32 bit avisynth, or that it's loading the 32 bit AviSynth in the first place.
I then get the message "Avisynth did not return a clip"
This is in version 0.8.2 with the .2 patch.
Any help would be appreciated.
Mark
Re: Cannot load a 64 bit DLL in 32 bit AviSynth
Hi Mark,
Have you made sure the "Use x64 AviSynth" is unchecked in the "A/V Media"-decoder? Or maybe you're not using the decoder in your workflow?
