AutoIt Error
kibi
AutoIt Error
Post by kibi »
11-01-2018 17-40-12.png (12.55 KiB) Viewed 18957 times
I start to get error at line 3353 in def_runner.exe in 0.8.2.2 version.
There are the same several messages.
Alexander Sorkin
Re: AutoIt Error
Thanks for reporting! :-) I Have located the error and it will be corrected for the next version (0.9.0).
kibi
Re: AutoIt Error
Post by kibi »
Do you have any road map when 0.9.0 is published?
Alexander Sorkin
Re: AutoIt Error
My aim is by mid february.
veks
Re: AutoIt Error
Post by veks »
I've got this problem today, similar:
http://prntscr.com/qluj5o
veks
Re: AutoIt Error
Post by veks »
veks wrote: Fri Jan 10, 2020 2:11 pm I've got this problem today, similar:
And this happens only if I add old workflow.
Thoughts?
I need this up and running ASAP.
Re: AutoIt Error
Hi veks,
Could you please export and post your workflow?
veks
Re: AutoIt Error
Post by veks »
admin wrote: Fri Jan 10, 2020 4:30 pm Hi veks,
I've noticed that this problem started when I added conditional "main_branch" and few success and fail ends so that I can have a status for them.
As described here: viewtopic.php?f=5&t=543&p=4665#p4665
Wherever I import that workflow in whichever ffastrans installation, on any PC I get AutoIt error when I try to start the workflow.
I can't send you the workflow publicly, as I mentioned before.
Thank you!
Re: AutoIt Error
How many nodes do you have in your workflow?
Re: AutoIt Error
..and what is the reason why you did not answer my PM asking the same question as steinar above ;-)
