Plan task
Plan task
I wonder if it is possible to plan a task like activate a monitor folder or another process to start the first node at fixed hour.
In fact, I would to use FFastrans to execute several delete or move from folder to another (or maybe delete files).
Anyway, I know that we can use windows tasks or "AT" command to plan but can I use ffastrans to do that?
I tried with "%i_hour%" equal to "12:00" (conditional node) but doesn't work. With command executor and "forfiles" command, the command processes all the time and I have monitor messages all the time for each file and each time a new file comes...
If someone knows a rule to do an automatic delete each day at the same hour it will be kind.
Thank you very much.
Re: Plan task
I think you better have a look at "Windows Task Scheduler" for these sorts of things. FFAStrans is not that kind of tool. At least not in the current versions.
Re: Plan task
Ok that's clear. I will used windows tasks.
Thank you Steinar.
Regards
