RE: FFAStrans Not Doing Anything on Windows
JohnB1
Post by JohnB1 »
I have installed the new FFAStrans, and it is not allowing me to do the following:
1) Located my workflow folder - it keeps going back to the original default root it set
2) Not allowing me to create a new workflow, but it allows me to create a new folder
3) Not allowing me to do anything with the current workflows - tried to stop, start and disable them, but still staying the same
4) When I input commands in any of the nodes, it goes back to being blank when I press ok
5) Can't import any workflows
6) Can't delete any of the workflows
I have tried to delete everything and start again but it's still the same results.
The Local processing tab does say "Active as application" if that helps in anyway.
Re: RE: FFAStrans Not Doing Anything on Windows
It really looks like you don't have write access to Your FFAStrans folder. Can you please check?
JohnB1
Post by JohnB1 »
I have checked my folder permission and I have read and write access
JohnB1
Post by JohnB1 »
I have found the fault and fixed it.
May I ask what the problem was?
JohnB1
Post by JohnB1 »
It was a user setting for read and write. It was set for something else and not for my account.
