FFastrans 0.8.2 folder created
Not sure it is an error but with FFAStrans 0.9.0, when I start the monitor status, a "FFAStrans0.8.2" is created on my desktop.It seems to be the logs of monitor status (A folder for each my worflow and a file called wflof.txt inside).
I think there isn't option to move it elesewhere in FFAStrans configuration.
Thanks.
Re: FFastrans 0.8.2 folder created
Can you please download this patch and see if it solves the problem with the log files?
http://www.ffastrans.com/download/FFASt ... 0_patch.7z
Problem solved with last patch (0.9.0)
Thanks and good job!!
