bug in conditionnal
bug in conditionnal
I discover a little problem with conditional node.
I populate a variable (f ex :%s_tcfoundsomm6%) and just after create a conditional node which choose between nothing in variable ( %s_tcfoundsomm6% = (empty enter)>>success
or something in variable >>error
Like this:
It seems possible because It works. But after a while this conditional mode becomes like this without any editing :
-----can't put another url in this message------
Re: bug in conditionnal
As you see the "then" appears in bad place and the node doesn't work anymore.
Have you ever see that?
Thanks a lot.
Ah, yes I have seen this two times before and I thought it was me cocking up the node when testing some weird stuff. Also I could not immediatly see what the problem was at that point but this will be fixed now. Thanks for reporting! :-)
