FFASTrans 0.9.0 Avisynth plugins errors
kibi
Post by kibi »
Tried to use RoboCrop and AutoCrop (x86 and x64 versions). Both crashes with the message:
[avisynth @ 00000041714634c0] System exception - Access Violation.
When debugging AVIsynth script via AVSPMod, using x86 Avisynth+ library from FFASTRans installation - everything is OK.
When running script via FFASTrans - in x64 mode - crash. Tried to set 32-bit setting for the workflow, but it is ignored, since in working dir of workflow it starts "Processors\FFMpeg\x64\ffprobe.exe" not "Processors\FFMpeg\x86\ffprobe.exe".
Unfortunately I can not find AVSPmod for x64 Avisynth+ to test these x64 plugins.
UPD. Tried to run command manually, replacing x64 by x86:
C:\Windows\system32\cmd.exe /c ""F:\FFASTrans\Processors\FFMpeg\x64\ffprobe.exe" -i "F:\FFASTrans\.work_media_cache\20160609150744\20180313-042503-884-B81B6D8E5AAF\op_cond_20180313-042505-775-841DBDB59A7C.avs" -show_streams -show_format"
Can confirm:
  • there is some issue with x64 Avisynth+ plugins and
  • FFASTrans ignores Workflow Options / Special / Force 32bit dependencies
avs_plugins.7z
(170.66 KiB) Downloaded 890 times
Alexander Sorkin
kibi
Re: FFASTrans 0.9.0 Avisynth plugins errors
Post by kibi »
Have downgraded to 0.8.2.2 and it works in both ways - x64 and x86 modes process the same Avisynth scripts with the same plugins predictably OK.
Maybe the reason is not stable FFMPEG build?
Alexander Sorkin
Ok, it might be the new version of ffmpeg or avisynth+ that's incompatible with the plugins. You can try and use the avisynth+ from the 0.8.2.2 version in 0.9.0 and see if that helps. You just need to copy the "avisynth.dll" and the "plugins+" files from the ffmpeg directories in ffastrans.
Also, the "Force 32 bit dependencies" works as it should in my tests. Could you send me the workflow so I can see if there something off with it?
kibi
Post by kibi »
Found the most recent builds of AVSPmod at forum.doom9.org.
There are both x86 and x64 versions, and I can finally use exactly the version of Avisynth coming with FFASTrans. Within it's environment and plugins. :D
Alexander Sorkin
