Custom AviSynth script help
Hi there,
I come around some problems using the AviSynth Node. When using .avi-files, it is straight forward. But with .mov in combination with the A/V-Media and ChannelMapper-Node I do not get the point to get it up working.
The Help-File says, there would be some demo-scripts, but I only found the QTref-Example-Workflow (which, by the way, works fine - thanks to all contributors!).
I Do not know how to tell the AviSynth-node the video-source. The AviSynth-Help has it like this:
AVISource("somevideo.avi")
This works with .avi-files.
Do I have to fill in a source-name at all? Or is this done automatically by the A/V-media-node?
Any help appreciated...
thanks in advance,
tom
Re: Custom AviSynth script help
...I found this:
viewtopic.php?f=5&t=220
I will give it a try!
thanks anyway,
tom
