Bug on XDCAM encoder (Avid Project Struture)
Hello Steinar,
Seems to be a bug when create an Avid structure with XDCAM encoder. The encode is ok but when FFAStrans delivers files, it should deliver 1 video file and 4 audio files (in my case) but FFastrans tries to deliver 5 files with same name so error "file already exists", only the first file is delivered.
The DNxHD encoder avid structure is ok, FFAStrans delivers 1 video (with _v1 suffix) and 4 audio files (_a1,_a2,_a3,_a4 suffix) > no files already exists.
Can you check please? Thanks
Re: Bug on XDCAM encoder (Avid Project Struture)
Yes, you are correct! The bug has been located and a patch will be released in a couple of days. Thanks for reporting! :-)
