Interlacing problem with A / V Media and DVC PRO
Clem4884
Post by Clem4884 »
When I use an A / V media then a DV / DVCPro and then a Watermark, there is an interlacing problem.
If I delete the A / V media and necessarily the Watermark, there is no problem.
Is this a compatibility problem between A / V media and DV / DVCPro?
Small precision, no problem on previous versions, problems appear on the latest version, 0.9.0.2.
Thank you
Re: Interlacing problem with A / V Media and DVC PRO
Hi Clem4884, thank you for using FFAStrans and welcome to the forum! :-)
Yes, I can confirm that there is a bug in the "Watermark" (and "Videolayer") filter(s) and it has been fixed for then next patch that will hopefully be released later today. Thanks for reporting! :-)
