Loudness Analyzer: Measuring Loudness Range
novalis
Post by novalis »
the loudness analyzer is a great help and it would be even better, if we could measure the third im portant parameter Loudness Range (LRA) as well. For most stations we must be within a specified range for this as well.
Additional info to LRA is provided in EBU Tech 3342 (https://tech.ebu.ch/publications/tech3342) - but it seems to be a little bit more complicated than the rest....
Thanks in advance!
Lukas
Re: Loudness Analyzer: Measuring Loudness Range
Actually, LRA measuring, both high and low is implemented in the current "Loudness"-node but commented out in the source code. It's very easy for me to enable it if it's desirable. But at the moment, there are no inbuilt functionality to make use of the LRA measuring from within FFAStrans other than for reporting. That's why it was disabled in the 0.9.0 release.
novalis
Post by novalis »
great! For me it would be desirable - we use the reporting to give the values to other apps or databases, so it would be great to have the LRA values, even if we can't manipulate those within FFAStrans.
Thanks a lot, Lukas
novalis
Post by novalis »
so could you activate the loudness range measurement in 0.9.2?
Yes, I can do that:-)
