Time code start from zero
Re: Time code start from zero
Hi pegasus, thank you for using FFAStrans and welcome to the forum!
Thank you for those kind words. This option will probably be added in the next version. It should have been added long time ago. Thanks for notifying.
espamtado
Post by espamtado »
I agree with pegasus about the excellent software and also I would like to be able to specify timecode manually on the encode modules (not only start from zero) because different TV channels want different start timecodes. Now I am specifiying timecode with the custom ffmpeg but is not very convenient.
Thank you
Custom time codes on all applicable encoders will be available in 0.9.2.
