%s_original_path~1% not working in 9.0.1?
Hi there,
anyone else with this problem? I Cannot get the function back to live even with workflows which worked properly in older versions.
%s_original_path~1% should give the folder-name "folder100" from path "d:\extras\films\dvd\folder100" but it does not seem to work anymore.
any suggestions?
thommes
Re: %s_original_path~1% not working in 9.0.1?
Hi ThomasM, thank you for reporting!
I can confirm the bug and it will be fixed for the next release. Sorry for the inconvenience!
...great - thanks!
thommes
Hey Steinar,
I desperatly need this function again. What if I roll back to an older version? The behaviour of FFAStrans as I figured out is, that, if you open a node from a previous version of FFAStrans, the program wants to save the workflow even if you not changed anything. I think this is because of some changes in the code of the node or some enhancements in the UI of that node. But anyway - how does this affect a rollback to an older version of FFAStrans? And how far can I go back?
I Have 0.9.1.11 FFAStrans.exe where this function does not work. I Think it worked in 0.9.0.xx. Do you think I can roll back?
thank you in advance,
regards,
tom
...ignoere my last post - with 9.2.x everything works well again.
Thanks a lot!
thomas
Post by taner »
Yeah, there are not many things in life which are as satisfying as %s_original_path~x%
In the end we found each other again
love it !
