REST API: Using different port than default is not working
trotskylenin
Post by trotskylenin »
Hello Steinar,
I'm going to report you two little things I found using the Rest Api.
This is the first, I've tried to change the port it works on with no luck.
After installing it as a service with a different port than the one that is set as default I couldn't enter the discovery page.
I thought it could be an antivirus or windows firewall issue, but it remained happening after disabling both.
If I use it with the default port, it works fine!
Regards!
Re: REST API: Using different port than default is not working
Hi trotskylenin, thank you for using FFAStrans and welcome to the forum! :-)
Thanks for reporting! It's a silly bug and it will be corrected for the next release.
