0.9.2 - Audio Extraction - Conform volume not working
Post by taner »
Great new version, Thanks!
But sadly I have a problem concerning the audio-extraction-encoder.
When I submit a (wave-)file to analyze-loudness and afterwards to audio-extraction-encoder to conform volume and true-peak I get no output.
Workflow starts, all steps are shown and processed in status-monitor until the last ones (delete original, delete cache) but in the output-folder the transcoded file does not appear.
Status-monitor shows "success".
This happens with any file I submit.
When I tell the workflow to "keep job work folders on completion" I can't see any file in the cache-folder
When I use audio-extraction-encoder without conform volume it works, I get an output-file.
Below a screenshot. Maybe it is not a bug and I make something wrong, used Analyze-Encoder until now just for reporting (generate text file).
Re: 0.9.2 - Audio Extraction - Conform volume not working
Thanks for the report, Taner. I'll take a look at it.
Well, I'm sorry but the last option in the "Audio extractor" shows I've been experimenting with the true peak implementation. However, it's not completed and the option should have been removed prior to release. It was sloppy and I'm sorry for the inconvienience. :oops:
The problem is also present in the other encoders also so expect a patch asap! Thanks for notifying! :-)
