Line 53338 Subscript used on non-accessible Variable
I am trying to run ffastrans version 0.9.2 version on my NAS storage it is showing attached error meassage. we want design transcoding farm.
Please find attached image file.
Dinesh
Dinesh
- Error.PNG (24.39 KiB) Viewed 18487 times
Re: Line 53338 Subscript used on non-accessible Variable
Sorry Its not NAS ... we are trying on SAN storage..
Thank you for the report
I will investigate!
Thank you..
I am waiting for solution..
At what point does the program crash?
When i am trying to run FFAStrans.exe from my SAN storage. it is showing AutoIT error message.
-Dinesh
-Dinesh
Thanks! Can you please try and rename the "Workflows" folder and try again? Create a workflow, save and exit, then start FFAStrans again and see if it crashes.
Thank you for suggestion..
I have rename the workflow, even created new workflow , save and exist. but it is showing same result (AutoIT error)..
same FFAStrans.exe would be run on NAS storage.. only issue is occurs for SAN storage.
-Dinesh
-Dinesh
No, I mean the folder named "Workflows" that's in your FFAStrans directory. Just momentarily to rule out corrupt workflows. The error you're seeing suggests that it might be the issue.
Even i had tried with fresh without creating any workflow ffstrans setup. It is showing error message.
-Dinesh
-Dinesh
