Delete Cache after transcoding
dinesh24
Post by dinesh24 »
We want to delete cache after completion of job. please let me know if their is any setting for that.
Dinesh
Re: Delete Cache after transcoding
Hi Dinesh,
What cache are you referring to? The one that holds file history or work files?
dinesh24
Post by dinesh24 »
I need to delete work file. it would taking more storage space...
If you have not done anything to NOT delete work files, FFAStrans will always delete them. You can change this behavior in the workflow settings under "Maintenance".
