Command executor@myvm: Process exited with error code: 1
robdot
Post by robdot »
Hi guys,
Does anyone know why I get "Command executor@myvm: Process exited with error code: 1" when trying to tun FFAStrans on a virtual machine and the files are on network drive M?
Any tips will be greatly appreciated.
Thanks,
Rob
Re: Command executor@myvm: Process exited with error code: 1
Hi Rob, thank you for using FFAStrans and welcome to the forum! :-)
The exit code comes from your command, so you need to look at the documentation for that command. Exit codes above zero usually indicates an error. If you don't want FFAStrans to foreward the exit codes > 0 as an error state then select "Omit exit code". The will make your node succeed no matter what your command does.
Hope this helps:-)
