Localizing file
robdot
Localizing file
Post by robdot »
Hi guys,
I have been using version 0.7.5 and decided to upgrade to the latest version. Using the new version (same workflow) the process is stuck at 0% Node 1/7: Localizing File...
Any tips?
Thanks,
Rob
Re: Localizing file
Can you please shed some light on what monitor node you're having problems with?
Re: Localizing file
Hi rob,
what is the OS you are working with? Maybe it is the win 10 AV-problem. Then the "processor.exe" in C:\[Appfolder]\FFAStrans\Processors is killed / erased by Windows Defender. Check out the forum-thread viewtopic.php?f=5&t=656 for more info.
But I think you got it working because of your newer post...
tom
