move after scan instead of just copying
robdot
Post by robdot »
Can FFAStrans move a file after it scans it instead of copying it?
Thanks.
Re: move after scan instead of just copying
Hi Robdot,
check out the "command Executor"-Node. There you can specify wheter to copy or move a file wit a simple windows-CMD-Command. A first hint is in the help-file.
hope this helps.
regards,
tom
There is a checkbox in deliver processor that says move....
