Is it possible that FFASTRANS can pickup and process subfolders from the ftp site?
Probably every week there will be manually added new programs. The dynamic part in ftp (AlbertTV, ChrisTV, ….)
ftp://tt888@ftp.tt888.nl
/omroepen/SIEN/TESTOMROEP/Instarts/AlbertTV/*.*
/omroepen/SIEN/TESTOMROEP/Instarts/ChrisTV/*.*
/omroepen/SIEN/TESTOMROEP/Instarts/< ????TV >/*.*
Accept files: *.mpg, *.mov
/omroepen/SIEN/TESTOMROEP/Full_Program/*.*
Deliveries Transcode IN
\\evs-smb-01\PROD-SIEN\TaskMedia\Transcode_IN\TESTOMROEP\Instarts\<dynamic>\*.*
Deliveries Transcode OUT
If *.mpg then copy to \\evs-smb-01\PROD-SIEN\TaskMedia\Transcode_OUT\TESTOMROEP\Instarts\<dynamic>\*.*
And If *.mov then create mpg and copy to \\evs-smb-01\PROD-SIEN\TaskMedia\Transcode_OUT\TESTOMROEP\Instarts\<dynamic>\*.*
\\evs-smb-01\PROD-SIEN\TaskMedia\Transcode_IN\TESTOMROEP\Full_program\*.*
If *.mov then copy \\evs-smb-01\PROD-SIEN\TaskMedia\Transcode_OUT\TESTOMROEP\Full_Program\*.*
And If *.mpg then create mov and copy to \\evs-smb-01\PROD-SIEN\TaskMedia\Transcode_OUT\TESTOMROEP\Full_Program\*.*
Cleanup Deliveries files in Transcode IN
FTP and dynamic subfolders
Re: FTP and dynamic subfolders
Hi asmit1, thank you for using FFAStans and welcome to the forum!
Yes, recursive folders in FTP was added in 0.9.0. So all you need to do is check "Recurse" in the FTP monitor. Use the %s_original_path~n% variable to get the dynamic folder:
\\evs-smb-01\PROD-SIEN\TaskMedia\Transcode_OUT\TESTOMROEP\Instarts\%s_original_path~1%
