Help for a avisynth script
I discover a avisynth script that can be useful for me(interframe). Unfortunately I never use avisynth script and of course never use into FFastrans.
I moved my avs script folder (interframe) into FFastrans-processor-avs_plugins folder.
I know I must create Folder monitor-av media-custom avisynth script- but deliver me a avs file... I forgot something.
My final goal is to use interframe avs plug to create interpoled frame from a progressive video 25p to 50i.
Someone can be help me please?
Thank you very much.
Re: Help for a avisynth script
Hi Benjamin,
Are you able to create a working AviSynth script without FFAStrans? If not, please do that first. When you have, please submit the workflow you have tried to create using your script. Working with AviSynth in FFAStrans demands basic knowledge in using AviSynth without FFAStrans: viewtopic.php?f=5&t=235
Ok I need to work about this kind of script because I don't know how it works at all... :D
I will try and I came back.
Thanks.
