Overwritten file is not seen by Monitor Folder
lbruins
Post by lbruins »
I have an XML that gets updated every hour that needs to be copied to another directory.
Often, the content is identical so only file date is changed.
So I start my workflow with a "monitor folder" processor, and this works fine the first time.
But when I overwrite the source XML with an identical or changed content, FFAStrans doesn't see it is updated.
It only works when I delete the source file, and then write the file again (with the same filename).
Question: can FFAStrans monitor file date (change/create) and/or filesize to see that the file is updated and needs to be copied to the destination?
Thanks a lot!
Re: Overwritten file is not seen by Monitor Folder
Hello Ibruins,
Well, I think you can do like that :
Monitor folder-delivery folder-command executor
So, check if the "forget missing file is checked" in your folder monitor. Then, check you have checked "overwrite" in delivery node. At last, add a command executor node(just after delivery node) which delete your source file after delivery.
First time your xml will be processed, delivered and deleted. When you put again your xml, it will be processed, delivered(overwritten) and deleted again, etc.
It could be good, hope I understand well your demand.
lbruins
Post by lbruins »
Hello Benjamin,
Thanks for your reply. There is one thing I didn't mention in my original question: this XML must always exist on both locations.
To be more precise: I have an application that (over)writes every hour an XML file to a path like: /production/filename.xml
Most of the times, this file is identical (although with an updated creation date), sometimes it's content is updated.
I need this file to be copied to /test/filename.xml
Both files need to exist at all times, because it is used by another application.
So: can FFAStrans copy a file, when it is not new but only overwritten?
Hello Ibruins,
So ok, in that case you have to add a command executor for clear the cache record.
Add a command executor node after your delivery and put in this command
%comspec% /c "if exist "%s_cache_record%" del /f /q  "%s_cache_record%""
Now, after your delivery, the cache of FFASTRANS is cleared and the copy begins again and again etc...You have a loop.
To avoid too many loop, in properties workflow menu, set a big sleep timer for ex : 1800 sec (30 min) or more.
Now, each 30 minutes your file will be copied (same file or not).
Unfortunately, if your file is updated 5 minutes after the ffastrans sleep timer, you must wait 25 minutes to have your updated file in delivery folder...
I don't know how you can do other way...
Hi Ibruins, thank you for using FFAStrans and welcome to the forum! :-)
Benjamin gave you some good clues and I would like to expand upon them a bit. Like Benjamin wrote, use the "Command executor" node to delete the monitor record. You can set a lower loop if you want, like 15-30 seconds. FFAStrans will never see changes in realtime anyway so some seconds is needed wether you like it or not. Then, you can use the $read function on both the monitored file and the destination file and compare them both using the "Conditional"-node, like this:
Now you connect to it the "Folder"-delivery node. Also, connect to it the "Command executor" for removing the monitor record and set to execute on both (error and success). This should keep your xml updated with some seconds delay.
Hope this helps.
Ouuuhhh I really like your method, really clever :)
In similar way, is it possible to use conditional to compare modified date of source file and destination file? Or created date?
Anyway, always happy to learn new "tips" /D
Currently, FFAStrans has no inbuilt function to read file size and/or time created/modified/read of files other than the source input. But I think it would be a usefull addition for these scenarios. Thanks for your input! :-)
Yes, I think it will be very useful to have folder monitor with different possibilities.
Benjamin, Ibruins,
Take a look at this workflow: viewtopic.php?f=5&t=747#p2863
It's another method for continuously monitoring updated files. It might suit your needs.
Yes Steinar, I have already took it and I'm studying it. Very useful again, thanks :D
Just one question : What is the ~ signification please? (just before "phone.txt" in generate text file node).
