HTTP communicate Processor for Slack Integration .. SOLVED
mdh
Post by mdh »
Hello Guys,
I'm looking for a better solution to get slack notifications from FFastrans.
Actually I user the email processor to send emails to Zapier and Zapier posts to a slack channel.
But i just saw that you can do webhooks in slack, so my questions:
Anyone already figuered out if the HTTP Communicate Processor can be used for slack integration?
Best mdh
mdh
Re: HTTP communicate Processor for Slack Integration .. need help
Post by mdh »
Hey forum,
I was succesful, let me share it with you.
I made a simple SlackBot posting finished encodings to a slack channel. It's dead simple.
You just have to get a slack incoming Webhook URL this goes into the "URL Field".
Right to this you switch action to POST
In the headers Field bellow you change the Value FIeld next to "Content-Type" to json
And in the main Field you put Something in like
"text": "%s_original_name%"
that's all
Re: HTTP communicate Processor for Slack Integration .. SOLVED
Hi mdh, thank you for using FFAStrans and welcome to the forum! :-)
Glad you found out and shared :-)
