Submitting via Telestream Vantage using the HTTP Notifier
dvdboy
Post by dvdboy »
As the title suggests, I am trying to submit jobs to FFAStrans via Vantage's HTTP Notifier, and I think the part I'm getting stuck on is the HTTP Method, the tooltip of which says the following:
If I configure the settings like this:
HTTP METHOD: api/json/v1/jobs
I get the following error:
Detail/Last Error: Error: An error occurred during execution of the Message Task: HTTP Notify error: The remote server returned an error: (400) Bad Request.
And I cannot provide anything other than the host in the host field as per this tooltip:
If I ignore this, I get this error:
Detail/Last Error: Error: An error occurred during execution of the Message Task: HTTP Notify error: The remote server returned an error: (404) Not Found.
It seems that if the method is anything more that a single 'root level' statement, Vantage complains or malforms the request?
Thanks for any help offered!
Re: Submitting via Telestream Vantage using the HTTP Notifier
Well, I tried to recreate the issue using Vantage but was unable to get it working properly. And I'm not sure if it was me doing something wrong or Vantage/FFAStrans being douchebags. Did you ever fix it yourself?
dvdboy
Post by dvdboy »
I reached out to my first line support, but have not heard back at present, so I'm not expecting much at this point.
I've had to put my FFAStrans work on hold unfortunately to complete some other projects, but when I get a chance to pick things up again, I'll update the ticket.
Thanks for having a look though.
