I thing i am almost ready with amazing workflow on FFAStrans.
There is just only one more that i am wondering about.
And that is the frame rate conversion.
I usually need to deliver files as 25fps and often they come to me originally as 25fps so that is no problem.
But the only time when they are different is they are sometimes originally 24fps but need to be 25fps.
But my experience with frame rate conversion is that it is kind of impossible to convert frame rate and keep the same time without noticeable different. Specially when the video has some camera movement to the side you can so easily see lag once on every second because one frame is missing.
The way i have been doing this before (with Premiere and Adobe Encoder) Is simply speeding every 24fps up to 25fps so the file actually play 1 frame faster. But of caurse when i speed file up the pitch will increase by about 4% and then i have beeen using VTS plugin to correct the pitch.
Can i somehow let FFAStrans do that, speed the file up by one frame and correct the pitch back?
Or... does this frame blending tool do good enought job that 1 frame off or on is not noticeable?
Is it possible to add 1920x1810 25 interlaced preset to the XDCAM-HD encoding node since a lot of TV stations require interlaced and my orginal files are always progressive.
I am so sorry for all the questions but i am just so new with FFAStrans, ffmpeg and avisynth so i dont know where to start. I know so little that i dont even know how to google this
If i will manage to create workflow that i can use and delivery files with i will donate to FFAStrans.
