mov to imx-d10
eddiesteyn
mov to imx-d10
Post by eddiesteyn »
Hi all
I am having an issue with a new workflow. I have noticed that when converting some mov files to IMX-D10 mxf files then the last frame is being cut off.
I have tested various movs, some work and some don't and the mxf files I've tested all work.
I have so far managed to narrow it down to the the mov files which are being produced by my Vantage server are being cut by one frame.
Is this a known issue? Do you have any advice as to a fix?
Thanks for a great product.
Regards
Eddie
Re: mov to imx-d10
Hello Eddie,
Have you try to update your FFASTRANS with 0.9.3.2 ? I have read the 0.9.3 had some problem with D10.
Please, try and tell we.
Thanks.
Re: mov to imx-d10
Hi eddiesteyn, thank you for using FFAStrans and welcome to the forum! :-)
FFAStrans use ffmpeg for most of its decoding and if ffmpeg throws one frame from the files coming from Vantage, FFAStrans can probably not fix that. You CAN try an use the "A/V Media"-decoder and see if it behaves differently. The issue might also be with the file Vantage creates. Are there any other similarities between the mov-files that initiate the issue?
