how to start a workflow without looking at existing files
rmap
Post by rmap »
Is it possible to start a specific workflow without starting to convert the existing files?
Need help/advice
Re: how to start a workflow without looking at existing files
If I understand well you question, you ask if you can start a watch folder with some files already in? Yes you can, you have to click on "rebuild history" inside monitor folder to avoid to process files already in.
Hope I understood well.
Hi rmap, thank you for using FFAStrans and welcome to the forum! :-)
I'm planning another persistant option that lets you skip current files every time the workflow is started. But for now follow Banjamins reply.
Yes it can be useful Steinar, without, we have to delete files under 1 month (maximum cache).
I never tried but I think the files inside cache will be process, isn't it?
megam
Post by megam »
admin wrote: Tue Nov 06, 2018 9:56 pm Hi rmap, thank you for using FFAStrans and welcome to the forum! :-)
rebuild history is not working for me
Hi megam, thank you for using FFAStrans and welcome to the forum! :-)
How is it not working for you? Can you be a little more specific?
megam
Post by megam »
admin wrote: Thu Dec 27, 2018 9:35 am Hi megam, thank you for using FFAStrans and welcome to the forum! :-)
there is a folder TestIn I copy there 2 video.mxf FFAStrans transcodes these 2 files into the required format .mp4 in the TestOut folder everything is OK. When I delete 1 file from the TestOut folder and click Rebuild History, then FFAStrans does not encode this file again. If I do something wrong, please tell me
Hi-res to Low-res.xml
Workflow Examples
(7.79 KiB) Downloaded 981 times
Hey megam,
so 1 *.mxf file that has already been processed stays in the watchfolder - then you click rebuild history. And you would expect the 1 mxf file to be processed again, correct?
Cheers,
megam
Post by megam »
emcodem wrote: Thu Dec 27, 2018 11:12 am Hey megam,
Cheers,
emcodem, yes that's right
Ah, that's easy then, "rebuild history" does exactly the opposite from what you expect: it checks for all files in the folder and marks them as alraedy processed. I think what you want is to also check the "forget missing files" option.
Let me know if there are any more questions left!
