2 mono channels to 1 stereo channel
sebird
Post by sebird »
i'm trying to convert 2 mono channels (left-right) to one stereo channel. I tried some configurations with ChannelMapper without success... The solution is perhaps Avisynth but i can't manage it how i want... Actually i can have channel one on the left channel and channel two on rhight channel on output (with X264 coder). If i use Custom FFMpeg the sound is good but i have a frame problem on the video... Can you help me? Thank's in advance....
Re: 2 mono channels to 1 stereo channel
I don't see where is your problem, if you want to encode in x264, create a h264 node and put 1 in "discrete track"s and 2 in "total channels" (FFASTRANS v 0.9.3) you will have 1 track with 2 channels.
Is this that you want?
sebird
Post by sebird »
thank's for your answer. In fact i would mix channel 1 and channel 2 onto 1 stereo channel. Each channel on each side. With this configuration i have channel 1 on the left and channel 2 on the right.
Hi sebird,
I'm a bit confused about what the issue here is. Do you want to mix the channels and thus create dual mono (same on L and R)? By nature FFAStrans will distribute channels as is to the layout specified on the encoder. So under normal stereo scenarios you will have mono channel 1 -> L and mono channel 2 -> R. Is this not what you want?
sebird
Post by sebird »
thank's for your answer!
Yes i want to mix the channels and make dual mono. In the H264 coder layout i can use only 1X2. If i choose 2X1 or other one it stay at 1X2 after save...
Hi sebird,
what i do to get 2 mono tracks (each one channel of course) to map to one output stereo track is just to add this options to the custom ffmpeg:
-map 0 -map 1 -map 2
As the default output for mp4 h264 is one stereo track, i do not need to specify more than that.
What you mean by: "If i use Custom FFMpeg the sound is good but i have a frame problem on the video."
Ok, so the problem here is the mixing. Currently, FFAStrans does not have any inbuilt mixing capability so for now you will need to sort that out with a custom avisynth script or custom ffmpeg node. If you have tried any of those please share what you have tried.
Also, please update your FFAStrans. The "streams X channels"-method was changed in the latest 0.9.3 version.
