Can't execute a dos command
Hello all,
I need to modify the "modified date" of files in a folder. The dos command works well and there is :
"copy /B /Y file.mov +"
But when I put this command in an executor node, no way (error code 1).
My command executor script is :
%comspec% /c "copy /B /Y "C:\Users\ctvf2avidtech2\Desktop\TEMP\*.*"+" (for all files in folder)
I tried with %comspec% /c "copy /B /Y "C:\Users\ctvf2avidtech2\Desktop\TEMP\CASTLE_221118_GENINT1.mov"+" (with a real file name)
I tired even with complete path in dos and works well.
Any idea?
Cheers
Re: Can't execute a dos command
To test your command, i created a new empty workflow and insert the command executor component with this code an no other changes like checked anything.
%comspec% /c "copy /B /Y "C:\Users\my user\Desktop\test\*.*"+"
After saving the workflow and starting the component using rightlick-> submit file, the date modified was changed and i got success in the job monitor.
Is it possible you deal with a access right issue, e.g. UAC enabled and ffastrans running as Service using the System user?
Hello Encodem,
Thank you very much for your help, it's really possible you're right(it's the error message indeed "access refused"). I have now to find where is the issue.
Thanks again ;)
