issue with QT animation sources
bartcuijpers
Post by bartcuijpers »
I'm experiencing an issue when transcoding files which have the QT animation codec.
As you can see in the following example the images somehow gets corrupt (the image is supposed to be a still);
https://www.youtube.com/watch?v=dZjVffWonpc
I've tried several output codecs, but no luck.
I'm running the latest patch: 0.9.3.2.
It occurs random... so it's not an issue with the source codec or files in general.
I'll be glad to supply logs, if somebody tells me which one and where to find them.
Bart
Re: issue with QT animation sources
Hi Bart,
What does your workflow look like? Does it pass through the "A/V Media"-node? Have you tried creating files just using ffmpeg (not FFAStrans)?
