API call "Abort job" does not work for me
Hi steinar,
while creating the webui, i was not able to figure out how the "Abort Job" API works, i always got strange "empty" answers
When setting this url for a valid, running job in the browser, i get a text presented: Invalid resource : "/api/json/v1/jobs/20181216-195117-270-5355A49682BE"
Here an example that should work when you run ffastrans on default port, it basically proves that using jsfiddle works (as you enable CORS thankfully):
Hit the "make request" link bottom right: https://jsfiddle.net/p5nryj72/
Here an example for the actual DELETE request that should abort a job. Sure you need to change the jobid in the botton left window but for me this does not succeed:
https://jsfiddle.net/643vLxs0/2/
To be honest, i am not 100% sure if i do anything wrong but i am confident that the error is reproduceable easily.
A sidenote, i am not very experienced with other http methods than GET and POST, usually it just works as expected. I personally dislike the use of different http methods, it overcomplicates things. Instead i just go with either url parameters or http header parameters and such.
Cheers,
Re: API call "Abort job" does not work for me
I think you must be doing something wrong. I just tried jusing POSTMAN (https://www.getpostman.com/) and it definately works using the DELETE method. I'm trying to do the "right thing" when it comes to using different methods but I can see using other than GET and POST might be cumbersome. At the same time, sending a DELETE to a job seem to be logical (and easy) and no extra payload (JSON body) is needed.
Anyway, here's the output from the rest_service when you send your delete command:
OPTIONS /api/json/v1/jobs/20181216-195117-270-5355A49682BE HTTP/1.1
Host: localhost:65445
Connection: keep-alive
Origin: https://fiddle.jshell.net
Access-Control-Request-Method: DELETE
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36
Accept: */*
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.9,nb;q=0.8,da;q=0.7
As you see, you have OPTIONS as method and DELETE is set in the "Access-Control-Request-Method", which the service currently does not understand. The following is from POSTMAN (and working):
DELETE /api/json/v1/jobs/20181216-225722-643-F1235D5E7DF1 HTTP/1.1
Cache-Control: no-cache
Origin: chrome-extension://fhbjgbiflinjbdggehcddcbncdddomop
Postman-Token: 1128aa28-75c4-7021-eea8-8e8d237481d5
Content-Type: application/json;charset=UTF-8
Accept: */*
Ah, i suspect i know what this is about... as i use the Browser the OPTIONS call is automatically added for CORS communication. Working around by using a proxy to my own webserver which forwards the request might help. I hope node.js can do that...
I have improved support for the OPTIONS method in the next version. Currently now tested with POSTMAN and working.
Hah great stuff, i can confirm in the beta the OPTIONS works, thanks, that makes life easy :-)
Funny that the browser generated this special call only for the DELETE method...
By the way, I was also able to workaround by proxying the call through my webserver which i guess is the preferred method for communicating with the API anyway. Using a proxy allows the client to communicate with a single server instead of 2 - in case the webui is not installed on the same machine as ffastrans.
Cheers,
