Watching a forlder for After Effect Files ?
synxmax
Post by synxmax »
Hi there,
I just found your awesome tool and it's such a time saver, Already saved me a ton of time
I was playing around trying to make it work in my after effect pipeline
Is it possible to make it watch a folder recursively for ".AEP" ( After effects project ) files and execute a command like :
aerender.exe -project "%AEP FILE%" -comp "render_1080" -RStemplate "R1080" -OMtemplate "R1080" -v "ERRORS_AND_PROGRESS" -mem_usage 60 10 -output "%OUTPUT"
and after render watch for output folder to transcode ( this part I figure out ) but the first part I have a problem getting it to work since I can't quite understand variable template literals and such
Any help is going to be appreciated,
Thanks in advance
Re: Watching a forlder for After Effect Files ?
Hi synxmax, thank you for using FFAStrans and welcome to the forum! :-)
Just enable 'Recurse' in the monitor and FFAStrans will search in subfolders.
The command should be executed using the "Command executor"-node like this:
%comspec% /c ""%programfiles%\Adobe\Adobe After Effects CC 2019\Support Files\aerender.exe" -project "%s_source%" -comp "render_1080" -RStemplate "R1080" -OMtemplate "R1080" -v "ERRORS_AND_PROGRESS" -mem_usage 60 10 -output "\\server\share\path\to\output""
Of course you need to change your paths (and CC version) to suit your needs :-)
Hope this helps.
synxmax
Post by synxmax »
Holy Moly :D Seriously You Guys Rock
I will test it out and let you guys know,
Thank you, Really Appreciate it
synxmax
Post by synxmax »
@steinar
Thanks again for the solution, There is one problem, Command gets executed successfully and it seems to render ( cause it takes the exact amount of time if I were to run the command manually ) but there is no output!
I tried to specify the output several ways
-output "c:\render.mov""
-output "d:\render.mov""
-output "d:\""
I had no luck, command gets executed successfully but not output
Is there something I have to do differently?
I played around with s_source_path and tried different methods to get the output but no luck
synxmax
Post by synxmax »
Ok I set aerender to output the log
I get this error :
aerender ERROR: No render settings template was found with the given name.
When I try to execute from command-line works fine but through FFAStrans seems not working
Trying to investigate more :)
synxmax
Post by synxmax »
Alright SOLVED :D :roll:
You have to run FFAStrans as Administrator and Program Mode, not Service
I don't know If there is a workaround service but It's cool for me
Seems there is a problem with aerender when it's getting called with limited permission it can't parse AEP files
https://forums.adobe.com/thread/1982647
Thanks again for help with command
Nice that you figured it out!
I guess it also works to run FFASTrans as service but setting logon credentials to the ones from local administrator.
Also, writing directly on Drives, e.g. C: and D: is by default not possible due to security restrictions; but it should work to write into sub directories, e.g. D:\Files - this might also work when the Windows service is running with default credentials (SYSEM)
