New API call for version?
Dear steinar,
would it be easily possible to add a version api call so i am able to determine if my API consuming code is prepared/tested for a specific version?
cheers!
Re: New API call for version?
Yes of course..i think so. How you think would be the best way to implement API versioning?
I guess that is an easy one, if you can just return a string representing the build number, e.g. the same as "Help->About FFAstrans": "0.9.4.44".
In other enterprise apps i know, this call works like a "test" call, it is the first thing that everyone who wants to use the API calls.
On the other hand, while creating the WEBUI, i noticed some strange things. I shall open another thread about stuff that makes life of API consumers hard soon...
Ok, the version will be inplemented according to your suggestion. I'm keen to know about all problems you encounter! :-)
