API user_variables hard to create and not visible in API while XML export shows them!
Hi again :-)
For the webinterface, i need to provide a manual on how to create user_variables but it looks like this part is somehow buggy. Maybe there are workarounds already known?
What i do when creating a new variable is to open the variables editor on a random node, e.g. populate varaibles. In the "Select variable:" window, i select the "User" tab (if any) and thne rigthclick - New. After that, the corresponding variable does not exist in the workflow export xml, nor in the API
http://localhost:65445/api/json/v1/work ... 1220091541
What i could already figure out is, that the created user_variable from above will exist in the exported workflow xml as soon as i started some job after registering the new variable.
But i did not yet manage to get out what is needed to get the variable visible in the API calls. I know it is possible because i already had some variables in the API calls but i don't know how to get there intentionally.
By the way, i did not yet manage to get ANY user_variables in the details call, even when the above one already shows the variable. I would love to use the details call, as the other one contains a lot less information. But currently i need to utilize both calls to get out all details ;-)
http://localhost:65445/api/json/v1/workflows/details
Cheers!
Re: API user_variables hard to create and not visible in API while XML export shows them!
A while ago I fixed several issues regarding dealing with user variables in different scenarios. The issues you're reporting are some of them so stay tuned for the next version. I will send you a beta-build so you can test your nice web interface :-)
Hey Steinar,
lots of thanks for the quick response, looking forward to the beta but take your time...
Actually i thought there might be a simple workaround as it seems to work sometimes... I guess one just has to know where to click in order to present the variable to the API as well?
Hey steinar,
very good news, i was able to find a workaround:
The user_variables are only presented to the api when they are (or have ever been) actually used in a value field.
So i can create and edit variables but only when they are used in some value field (i used populate to test, i believe it works with any value field), they are visible to the API.
In the end this makes somehow sense.. why should non used variables be presented to the API ;-)
This way i can write a nice user manual how to use the mighty variable feature for job creation on the WebUI
Cheers!
User variables not used in a workflow will not be exposed in the API (or the exported XMLs). As you point out, this makes sense and it's by design.
