as discussed, i open here a thread for dicussing a possible new unified job object (at least in the API). This time i'll not talk about boilerplate or green field but i'll take into account the current design.
Here a list of current job objects,
Queued
"item": {
"display": "Sony.mxf",
"guid": "20190101-170032-841-131F23D311C8",
"host": "DESKTOP-UIFQT86",
"localized": "D:\\Sony.mxf",
"original": "D:\\Sony.mxf",
"outbounds": ["enc_av_mp4 20181229-100059-462-cb5c7274c481"],
"source": "D:\\Sony.mxf",
"watcher_id": 20181220210008
"job_id": "20190101-165939-894-BED4019C406B",
"job_start": "2019\/01\/01 16:59:40",
"file": "%FILEPATH%",
"wf_name": "sleep600",
"splits": [{
"steps": "2 \/ 2",
"processor": "Hold",
"status": "%STATUS%",
"node": "%HOST%",
"progress": "50"
"steps": "2 \/ 2",
"status": "Resting workflow... (TTL:540)",
"node": "DESKTOP-UIFQT86",
"progress": "50"
}Code: Select all
"wf_name": "Loop_Start_Self",
"job_start": "2018\/12\/31 16:04:52",
"job_end": "2018\/12\/31 16:05:05",
"file": "60690",
"outcome": "Job aborted by: API Service@DESKTOP-UIFQT86",
"state": 2
}A combined object could look like this:
Unified job object:
"job_id": "20190101-165939-894-BED4019C406B", //from active, replaces guid from queued read comment!
"wf_name": "sleep600", //from active
"wf_id": "12345", //NEW
"job_start": "2019\/01\/01 16:59:40", //from active
"job_end": "2018\/12\/31 16:05:05", //from history
"state": 2 //from history, but now indicates if job is running, queued, success, cancelled or error
"display": "Sony.mxf", //from queued
"watcher_id": 20181220210008, //from queued
"outbounds": ["enc_av_mp4 20181229-100059-462-cb5c7274c481"], //from queued
"file": "%FILEPATH%", //from all, replaces "source from queued",could also be moved to splits?
"user_variables": [...] //NEW
"static_variables":[...] //NEW
"log_file": "%FULLPATH%" //NEW, could also be moved to splits, depending on future logging strategy
"split": { //from active but not array anymore, there is one job obj per split
"split_id" : "combination of split id and job guid", //NEW
"outcome": "%OUTCOME%", //from history
"steps": "2 \/ 2", //from active
"processor": "Hold", //from active
"status": "%STATUS%", //from active
"node": "%HOST%", //from active
"progress": "50" //from active
We could also get rid of the "split" object and move all it's fields to the root object.
Also important: all fields should always be there but have an empty value in case it is not yet known. This makes parsing a lot easier.
Sure this all might not be complete and it is a matter of discussion, also probably it will never be implemented.
