Muxing using BBC BMX (progress in status_monitor)
whenever the muxing starts, the progress doesn't show any percentage on the status_monitor of FFASTrans, however BMX transwrap itself does show a percentage if I use it myself using the command line.
I think that a progress should be added in the status_monitor showing the percentage of the muxing process.
Of course I can just go to the folder where temp files are and check the growing file size of the re-muxed file, but it would be way more useful to have it in the status_monitor.
Thank you in advance,
Frank.
Re: Muxing using BBC BMX (progress in status_monitor)
Of course, I will add it :-)
Time for a new patch release, perhaps?
Hey Frank,
just for info, new features will take a while as steinar mentions here:
viewtopic.php?f=6&t=832&p=3469&hilit=refactoring#p3469
