Need a precision about rest service
I'm going to change a little my workflow and I can't remember the difference between an installation of rest service with "run as application" checked and "run as application" not checked. I would know before make a new install.
If someone can help me it will be kind :)
Thanks a lot.
Re: Need a precision about rest service
If you are going to run the rest API, you can run it as application, that is from the FFAStrans workflow manager, or as a service, detached from the workflow manager. Either way, if you want to use the web interface from emcodem you MUST run it one way or another.
Hello Steinar,
Ok understood. But, if I choose as service and I open ffastrans application, is there a priority? Or it doesn't matter and the service goes on to work and appli can submit too.
Thanks ;)
If you run as service, the workflow manager will function as normal. It's just a matter of what system startet the engine, the OS or the workflow manager.
Hello, Steinar,
Ok I got it! Thanks and sorry for the question.
