Line 34220 error
greoli
Line 34220 error
Post by greoli »
Hi!
My workstation is crashing everyday around the same hour.
There is no interesting information in the Event Viewer.
After restarting the workstation, when I start FFAStrans I'm getting this message:
AutoIt Error
Line 34220 (File "C:\Program Files\FFAStrans\Processors\processors.a3x"):
Error: Array variable has incorrect number of subscripts or subscript dimension range exceeded.
If I start again FFAStrans it works normally.
Re: Line 34220 error
Hi greoli,
At what time does your workstation crash and do you have any idea what might be causing it?
The error is an indication of FFAStrans not being able to read the workflow properly. I see you're using the ProgramFiles folder. You are 100% sure you have full unrestricted read/write access to that folder?
