Insert media + Video layer
zkazzay
Post by zkazzay »
Hello Everyone,
First I would like to thank whoever developed this awesome tool that is FFAStrans! and also I'm noob at this, so bare with some basic questions.
Second, I'm trying to create a workflow where the objective is to Add an intro + Main clip with an animated logo and a graphic overlay + 3 outro clips, and export everything to mp4.
I got the workflow working easily, but the problem is that the animated logo overlay (in loop) starts at the very beginning of the intro media and I only want it on the main clip (after the intro clip).
How can i go past this?
here's my workflow:
Re: Insert media + Video layer
Hello Zkazzay,
I think you should apply your logo+overlay BEFORE insert your intro.
So apply your different overlays on the main clip ,insert your intro, yours outros and encode. I think no matter the order in the workflow, the important is to have the good order for your output file.
Try it and tell us ;)
zkazzay
Post by zkazzay »
Hello Benjamin,
Thank you! it worked! :D
i don't know how i didn't thought this way, but it makes a lot of sense.
Cheers!
Hi ,
You're welcome ;)
Don't worry, it takes time to "think" like our FFastrans.
T3S0R0
Post by T3S0R0 »
Hi, momocampo, your workflow works?, can you share me?
Regards.
Yes my workflow works but which one?
Seriously, what kind of workflow do you need?
Tell us what you want and we help you.
Cheers
