TEAMVIEWER
backlight
TEAMVIEWER
Post by backlight »
Hi guys,
i have noticed a lot of problems using teamviewer from android to "submit files" on a specific node.
The right click works perfectly inside the workflow but it seems to doesn't work on the nodes!
Have you any suggestions?
thank you so much
Luciano
Re: TEAMVIEWER
Hey Luciano,
very good question! ..submitting jobs using a different platform than PC sounds like a perfect usecase for the "new" webinterface:
viewtopic.php?f=5&t=789
The direct answer to your question might look like this: from a developer perspective, it makes totally sense that software like teamviewer makes troubles as the base programming language of ffastrans is just "simulating" normal windows behaviour. It might work better using some other remote control software like vnc.
backlight
Re: TEAMVIEWER
Post by backlight »
Tested with GOOGLE REMOTE and works FINE!
Ghtais
Re: TEAMVIEWER
Post by Ghtais »
Sometime I have to used teamviewer with FFAStrans and it works fines for me.
For everyday I'am using Remote desktop connexion on windows as My FFAStran computer is in the nodal and there is no pb.
Best
Re: TEAMVIEWER
A really nice software and free is Anydesk. Configure it well and it is really better than teamviewer (which contains too much ads).
Cheers!
