watch waiting files
nizi
watch waiting files
Post by nizi »
first off all ... thanks 4your greate work!
in the bugfix of 0.9.3 is this fixed:
"Fixed an issue that caused all submitted files to start processing without finishing the first."
this was fine to watch all submitted and waiting jobs in the monitor tool.
can you enable this only for the the monitor task?
or is there an other way to see all submitted and waiting files?
thans and best regards
pandadnap
Re: watch waiting files
Post by pandadnap »
Hi steiner,
same request here. Is it possible to should all submitted tasks in monitor instead of just the processing task.
In addition, it will be great if user can set priority to those submitted tasks.
thanks,
Panda
Hi nizi, thank you for using FFAStrans and welcome to the forum! :-)
nizi and Panda, currently FFAStans is undergoing a major refactoring and a lot of things will change. With that a lot of thing will be much easier to implement so you will have to stay tuned for a while;-) No new features will be added in the current 0.9.x branch.
