SOLVED Workflow works with watch folder on desktop but not server
GammaScorpii
Post by GammaScorpii »
I have a network folder mapped to drive W:\ in Windows. I thought that might have been a problem since I can't browse mapped drives in the monitor node, so I changed it to the ip address:
\\192.168.1.100\Sharedfolder
Nothing happened so I tried submitting a file to the workflow and I get the following error:
Job ended with error on A/V Media@PC: Could not recognize content in file!
The very same workflow works perfectly if I change the monitor folder to a test folder on my local desktop. Any ideas why? I do have jumbo frames enabled on my server, could that be it? My server is a synology if that helps.
EDIT:
Just did the process in reverse and tried to deliver the file to the server:
Could not deliver! Getting error code 1326: The user name or password is incorrect
How do I give permissions?
2nd EDIT:
Found this post https://www.ffastrans.com/frm/forum/vie ... 3192#p3192
Fixed for me. Thanks for this great program!
